Hi
I am getting ready to re install my renovated dash into my car, however I cannot remember what seal or piece of material was in place between the dash wood and the rear of the screen opening inside the car, there was a piece of leather trim that is stapled to the top profile of the dashboard which I have, but it looks like there was another piece of something between that and the screen opening also
anybody got any pictures or information ?, please see attached photo of what was in there originally
There are some Rexine covered plywood spacers that fit to either side of the demister vents.
Peter
Hi Pete
I have the plywood spaces in the car, do you have a picture, it seems that this material went all the way across the top of the dash but I don’t recall what it looks like
Mike
Rob, your car and mine were never fitted with heaters when they they left the factory. The MkIV has separate pieces filling the gaps that result from the demister vents.
Peter
I am going to do a tril fit up with the dash this week, from there I will measure the gap between the dash wood and the internal side of the windscreen, I know it had a strip of leather along the top of the dash to finish it off but I am still unsure of what was between that
I will post back when I have fitted it up
Thanks all
I think Rob is correct that part of finish is a piped rexine the same as used at the head lining. Here’s an unrestored example.
Peter
Thanks all for the Info and Pictures very informative
Mike
Right, somebody added a Delaney Gallay heater to mine, and would have removed the upper dash panel in order to cut notches for the defroster vents. So whether he notched the piping or put on new piping is unknown.
