Right.Brilliant.
Let’s close the site and post a reference to everyone to simply refer to their manual.
90% of questions would be resolved with that logic.
And the descriptions such as this are so useful often times as you know within them.
“Remove the 2 pan headed screws and remove the gearbox” … how?!
Even deciphering this, how does one even get their hand in there to remove said “gearbox”?!
Man I’ve worked on jaguars, and appreciate having to do occasional procedures by sense of touch, but I cannot recall even the ability to contortion my arm to reach up in there, otherwise I would have done so…I’ll look again.
…much less how the “gearbox”: would be removed…it simply states “remove it” in typical auto manual fashion.
Does it simply pull down and off as the pivot for the vent window is apparently flat at the end like a butter knife? Dunno…just says remove it.
I don’t want another broken pivot/window here…
…and what’s an NDV?
I already own 2 manuals, the large, original red S1 XJ6 manual and the Haynes for the S1 XJ6 series…neither of which mention the vent window.
So thanks, but no thanks…don’t need to purchase another manual for removal of the vent window, hence why there are forums such as this. Especially when I have a parts manual and still cannot figure it out.
Forums, sigh…nothing’s changed. All private little clubs between a handful of good ole boys (for the most part).
@MikeB : Yep, I’ve noticed that, thank you. Gooey stuff, but nothing I recall particularly revealed afterwards.
Ah, removing exterior door/window trim too? Ah, never thought that would be necessary. Yep, I’ve read that glass must be dropped all the way down for that…gotcha. Thanks
Will go out there again and see what I see. I hate operations like this that should be so simple, yet become so difficult. zzzzzzzzz
Regards
