So I’m working on a Series 2 that came to me with a new 60a alternator, installed but not wired. Fairly certain I have it wired right now, but it’s not charging, tested at the battery. I’d like to check the output at the alternator, to eliminate a possible wiring issue, can someone tell me how? Or point me in a better direction as often happens here.
There are numerous obvious wiring (and other!) bodges here.
Also the needle on the ammeter does not appear to move at all, and no ignition light (haven’t checked the lamp itself yet)
Thanks, Alan
