Two additions to Gary’s description, Roger…
‘Hi’ and ‘Lo’ are manual settings by the function switch - the ‘medium’ are controlled by the servo microswitches, with the switch to ‘Auto’. While raising or lowering cabin temp, servo engages ‘medium high’ to quickly acquire set cabin temp…
When set cabin temp is reached the servo resets to ‘maintain temp’ position - repositioning flaps and other functions. Including fan speeds dropping to ‘medium low’, which is an audible indication that set temp is reached…
In ‘Auto’ the system uses fan speeds as a ‘first reaction’ to regain cabin temp if it drifts off. So fan speeds can be used to track system efficiency - the longer the fans stays in ‘medium low’ the better. This basically also applies to the late versions with electronic speed controls…Secondly; while the system has 4 relays for 4 fan speed, using a resistor pack. Each relay connects to the motors through different resistance paths to vary fan speeds - except for the ‘Hi’ relay which connects directly to the motors for max speed…
On late ‘resistor’ versions, and a sometimes PO modification; the ‘medium high’ relay is also connected directly to the motors - the fans runs at full speed with the servo in ‘medium high’ position. This does not affect overall system operation - and, as an aside, there is not much difference between ‘Hi’ and ‘medium high’ anyway…
That the fans do not drop to ‘medium low’ in ‘Auto’ may just mean that set cabin temps were not reached? This can only be properly assessed by measuring air temps at the in-car temp sensor aperture.
If reaching the proper temp with no fan speed change - the fault may be the in-car temp sensor, or the temp selector. However, the servo action should be routinely checked - the servo should be heard to react when temp selector is varied between maxima. If the servo is not responding; the fault is usually a failed AC amp…
The temp control variations can also be used as a general diagnostic. Gradually altering temp selector setting with the system running; when the actual cabin temp is reached - the fan speed will drop. Another general indication is that in ‘full cold’, the centre vents are open - in ‘full heat’ they are closed.
A couple of ‘quirks’; in heating, the fans will not run until coolant temps reaches 41C. Another is that if cabin temps is below 65F the system will run in ‘full heat’, and above 85F; in ‘full cold’ - irrespective of temp selector setting…
A failed relay, or a microswitch fault usually means loss of that fan speed - a failed resistor pack will leads to loss of fan speeds above the relevant resistor break.
However, If the ‘Hi’ relay fails closed, not relaxing to off, there will only be high fan speeds…
In short; you need to do testing as suggested to clarify the problem - if indeed you have one. The initial tests can all be done while sitting comfortably in the driver’s seat. Including verifying that the compressor is engaging with the function switch out of ‘off’…
Frank
xj6 85 Sov Europe (UK/NZ)
