[quote=“00ring, post:9, topic:433414, full:true”]
Good morning Frank, I can verify manifold vacuum source at the “delay” port on what seems to best be called the vacuum controller. I can also verify ported vacuum source at the “carb” port. It seems your advise would best apply to omitting the controller and choosing one or the other to connect to the distributor and then time initial advance accordingly.
[(/quote]
I personally swear by vacuum advance, Scott - because I fully understand it…
But it is absolutely essential that you pick one or the other. You simply cannot use ‘manifold’ specs for a ‘ported’ vacuum source - or vice versa! They are different beasts…
The ‘delay’ cannot increase the vacuum delivered from the source - it can only regulate how much is applied to the dist. It is inappropriate and counterproductive on the ‘manifold’ set-up…
Manifold vacuum dictates cylinder fill, at 18" Hg it’s 40 % of ‘0’ vacuum, and mixture temp increase with cylinder fill in addition to burn temps. At ignition the burn spreads from the plug at a speed of some 40 m/s - and ideally; and burn should be completed a tad after TDC for max power. Which means increasing advance as rev rise to give adequate burn time.
However, if ign is too early; the combination of compression and burn heat may rise mixture temp to the ignition point of petrol before TDC - the remaining petrol then spontaneously ignites, detonates; the engine knocks.
As cylinder fill relates to compression temps and the fill relates directly to manifold vacuum; any drop in vacuum increases temps - using vacuum as an advance regulation is obvious. At cruising speed vacuum is high, as pedal is pushed, vacuum drops and ign instantly backs off - as directed directly to the dist.
The point is to maintain high advance at light loads, near ideal complete burn point without encountering knocking at high loads.
‘Ported’ vacuum varies with air speed through the throttle and the throttle position - and differs from ‘manifold’ vacuum in a less obvious/predictable (to me) way. So a delay valve is commonly used to mitigate negative effects on the advance…
In early days in Europe, at motor tax was introduced based on engine ‘hypothetical’ horsepower - by engine volume. And huge efforts wwere used to get the maximum power from a minimum engine. And ‘manifold’ vacuum advance regulation was considered best. The US, without such tax, increased engine volume for more power - to put it very crudely. And used ‘ported’ vacuum to cover other priorities. Generally, and for various reasons, Jaguars on US specs has less power…
It is more complicated than that, and either set up works well enough, but has different priorities. Generally, the most efficient use of petrol is to run the engine as close to the detonation point as possible - using computers to regulate advance. And fitting antiknock sensors as a back-up…
Frank
xj6 85 Sov Europe (UK/NZ)
