Hello all,
Robert_Wilkinson thank you for your suggestion!
You were right that something beyond the IVR was at fault!
Took the IVR out and bench tested it first for shorts (none) and then voltage with my DC power supply, âBâ input connection at 12V âIâ output to Instruments all over the show, but since itâs a Bimetal Circuit that goes on and off all the time and my Multimeter is not the best in the land I figured that was ok., mostly 10 ish volts.
Power on the car however was not happening, nothing at either âBâ or âIâ connections⊠telling, but one must be systematic or your just in for lots of frustration when your trying to sort out electrics.
Next was testing voltage to the plug
Red wire white tracer (light circuit)was fine.
Then check continuity on the wires from the IVR to the printed circuit again, all good, not pretty but good.
Blown away by the somewhat cheap nature of the printed circuit, itâs not a proper board on some sort of phenolic or glass fibre, itâs on some flimsy plastic sheet.
Checked the continuity as best I could on the car and then I noticed the classic signs of an overheated piece of copper in a circuit board lifting up and out due to overload/overheat!
So I unscrewed the board and instruments via:
6 screws that connect the printed circuit and the instrument innards to the housing binnacle.
The green and red wires to the IVR,
The nut and flat blades screw to the clock,
Finally the wire from the voltmeter to the ceramic resistor housing that has no resistor!
Now letâs see if we can solder in a wire across this
Cleaned the copper leads with some alcohol and used a piece of scrap glass fibre circuit board from another project underneath to protect the printed circuit from melting.
Out comes the Hako and I tin one side.
I grabbed a lead off of a 9V battery connector, close enough?
One wire connected, not my proudest moment in soldering!
The other side has plenty of real estate to tin.
And the wire was tinned and quick to connect to the copper strip.
Used a piece of electrical tape (white was all I had handy and wrapped it up.
Added another piece of tape on top for good measure.
Put it all back in and then turned it on to make sure no more smoke escaped!
All seems to be working now, better hit the Chevron before I go to work in the morning!
The only thing left to ask is if this bodge is good enough?!?! Iâll keep checking on it throughout the week, but Iâm wondering if I need to think about a new solid state IVR.
Or miracles of miracles this printed circuit sheet is still available?
Once again I get to see the voltage seem to low,
The oils pressure fluctuate to scary lows,
The clock forever at 12:19:12.5,
The temperature gauge that terrorizes me every summer!
And the gas tank that always seems to be on âEâ
Thanks again for all the help, case closed for now!
P.S Godfrey, I have found L.A. smog is an excellent and highly concentrated replacement for Lucas smoke!
