Bill and Steve I got the fitted hose recently from Classic Jaguar also. I just removed an old hose that looks in identical condition as yours and installed the fitted hose. So far just 15 minutes running in the garage after also doing the periodic coolant change and it seems like it will work much better than what I had. Thanks very much for the tip.
Did you happen to notice whether the end of the pipe fitting on the sump was strait or was it flared out? I don’t know if any were flared from the factory, but a lot of them seem to have been flared. Mine was, Drew’s was and other people’s also were. It may just have been a common, cheap modification people did over the years to try and get it to stop leaking.
If it is flared, and you use that silicone hose there, the sharp edge of the flare can dig into the inner surface of the hose. It did that on mine because I failed to notice it when I installed it. As a result it created a failure point and continued exposure to oil caused the inner hose liner to desleeve itself. Parts of It ended up in the filter housing and in the sump.
Silicone is more fragile and susceptible to mechanical damage than harder rubber is so if the pipe has been flared it would be very prudent to remove the fitting and flatten it out by rolling it around in a bench vice. Then it will be safe to use that hose. Clamp it only as much as needed to prevent leaks. It’s not under great pressure so that would 't be very tight at all.
As I mentioned, I got the flare out of Drew’s fitting in about 10 minutes by snugging it in a vice and rotating it until it turned easy. Then take another quarter turn tighter and rotate the fitting again. Keep repeating this until it’s half inch even.
I did not notice the flare since most of the time I was working by feel from underneath without a lift and with indirect light when looking from above. Now that I go back I think I can feel a flare at that spot when I squeeze on the hose. Thanks for the tip.
