Hello All,
I have been changing paper filters on myXK for the last 20 years and finally I have just bought a Spin-On Oil filter conversion hoping to make the job a little easier in the future.
Although a 150 car my engine is from a MK9 which has the same filter arrangement as a 140 (I believe)
I bought the kit from SNG Barratt (UK) which stated it was for a 140 with a Tecalemit housing which is what I have.
The problem I found was the O ring supplied with the kit is a larger section than the existing used with the paper filter and as a consequence will not fit into the recess groove. The difference (3.8mm vs 2.8mm) can be seen below. Original is the lower one.
The O-ring will fit within the housing (blue arrow) but straddles the recess (yellow arrows).
I have queried this with SNG but they have yet to come back to me. I was just wondering if anyone had come across this before and had a solution? I have plenty of spare original seals which I could use?
Any help much appreciated.
Phil
