My 1969 FHC has been a thorn in my side as long as I’ve had it.
I bought it at a collector car auction about five years ago.
I drove it home on the highway, a distance of about 30 miles, and then into my garage. Only about one mile on surface streets before parking.
The engine was flawless until I pulled into my driveway when there was one slight ignorable stumble.
The next drive, and every one since then have resulted in a stumble after about six miles or 25ish minutes, followed by more stumbles, backfiring and stalling within two more miles.
The car will only restart after a good rest, about 20 minutes. It will then repeat the symptoms after a shorter drive than the last.
It has lived much of its life in garages and being targeted by parts cannons fired by mechanics who routinely work on e-types and similar vintage sports cars.
Fuel delivery aspects of the problem have been eliminated with a thorough cleaning of the tank, a new pump, and a clear terminal fuel line delivering a constant 5psi of fuel with no air bubbles.
We’ve gone through many electrical parts including a new ignition switch, battery, grounding straps, 2 Pertronix ignitions, back to original points, multiple coils, with and without a ballast resistor, plugs, cap, rotor, plug wires, etc.
Today I decided to check the voltage to the coil with the engine off, and running/driving.
With the engine off, and the key in the run position, battery voltage was 13, and 11.5 at the coil.
While driving, coil voltage (no external ballast resistor) started at 5 volts and dropped to 4.4 while moving. When the engine revved prior to shifting, voltage dropped to about 3.2 and came back up to 4 with lower engine speed.
I’m hoping that this voltage is too low for the coil and it just gives up at some point.
If this is the case, could the tachometer be the culprit? If so how should I address it?
Grateful for all advice,
Dave in Miami, Fl.
