Just wondering if for example, you can swap a rim/wheel from an R model and directly bolt it on to a base or V6 Premium model. I thought that when I was researching wheel options, that I saw different bolt patterns for 18" or 20" rims. Doesn’t make sense that the bolt pattern would be different. Really like the Orbit wheel.
The car has to be recalibrated for your
Abs
Traction control
Speedometer
It’s a dealer plug in reset that takes about 3 hours😀
I’m not kidding…Ah modern technology
Gtjoey
You can get bigger wheels but you have to do the above or your dash will light up like a Christmas tree
Thanks for the reply. Just out of curiosity, I looked up the specs, specifically the diameter of 18", 19" and 20" tires for the F Type, and they are all within .3 " to .6" inches of one another. Of more disparity, is the width of the tires. I guess it’s one finicky cat with that little tire diameter difference to set off a code.
