Is it advisable to use a sealant (like Stag) on the xj6 s3 1982 4.2 ECU Temp sensor, or does the body of the sensor need to make a good electrical connect with the gnd of the motor and therefore better left bare ?
It’ll have a sealing washer; I don’t use any sealant and never had one leak.
The sealant/no sealant question remains pertinent for other sensors without a washer, however. I’m in the ‘no sealant’ camp but opinions vary.
DD
Isn’t it also very important to know whether threaded base provides ground… Unless there are conductive sealants?
The CTS does indeed require a good body ground, Zenit - but as Doug says; the washer provides the sealing, the threads provides the ground. Ie sealant is both unnecessary and counterproductive…
Frank
xj6 85 Sov Europe (UK/NZ)
Thanks Frank, just checked the sensor on the engine and yes the thread has no sealant and a very good earthing thru thread. But resistance between pins is all over the shop, varying depending on where the probes contact the pins and the pressure applied. Obviously, there is a bad connection internally. Swapping it out in a couple of days.
Thanks Doug for the article on the CTS resistance values, very useful.
A swap should then indeed cure the problem, Zenit…
Frank
