I am looking at restoring a 1981 series III XJ6. It has been sitting for 15-20 years now, and before I start working on it I want to make sure it has not seized. I am having difficulty finding/getting to the crankshaft bolt to try and manually turn it over. How do I get to this bolt?
You need a long flat piece of say 1/4” plate about 2.5” wide and about 18” long.weld to it a shortened socket that fits the crank damper bolt. You need a shortened socket so it clears the rad/fa. I’ve forgotten the socket size! But sure someone on here can advise.take spark plugs out, make sure it’s not in gear!
A simpler way if it’s got a battery on it, is to take the spark plugs out and see if it turns.
33mm or ¾ whitworth or the corresponding size 1 5/16?. Plugs out, oil in and cross your fingers. Fan belt not too likely as in my case it almost slips and it is very hard to get the engine moving by hand.
Yes, that’s what I meant. The Whitworth sizes are thread sizes but the tools are given their “names” or sizes that way. So a Whitworth 3/4" spanner or “box” is the perfect fit for the crank bolt on both XK and Jaguar pushrod engines.
Yes, 1-5/16" socket.
The thread is 3/4-16 UNF as is the rest of the XK engine except a few UNC where it is threaded into aluminum, and SU carbs if you have them are BSPP.
If you can’t get in there with the socket, you may be able to find a place in the bell housing where you can get a pry bar in there and pry it on the starter ring gear.
What country are you in?
a 33mm x 1/2" drive socket from below will usually get on it
1-5/16" is typically 3/4" drive and bigger, so not enough clearance
I have a cranked 3/4 Whitworth ring spanners that slips in from below right onto the nut and near flush to the pulleys, its a beauty
Now I dont want to dispute my olders & betters, but if you slip a 3/4W (1.300") and a 1-5/16" (1.325") over the nut, the 1-5/16 is a bit sloppy. (both 6 point sockets), 3/4W = 33.02mm
Me too. Just because a 1-5/16" or 33mm socket/spanner/wrench fit doesn’t mean that is what it is. It’s just that they both are close enough to the real size 1.300" 3/4" Whitworth. And if you take the time to measure the thread angle you will find it is 55 degrees (Whitworth) not 60 degrees (UNF). I have a 3/4" Whitworth socket (1.300") which is a nice tight fit, a 33mm socket (1.2992") that is indistinguishable from the Whitworth, and a 1-5/16" (1.3125") which is quite sloppy. All work of course, but only the Whitworth feels just RIGHT
Andrew if you are still waiting to get the correct spanner / socket you could try putting it in top gear, plugs out and handbrake off then give it a ‘rock’ / push back and forward. You will need an assistant to watch if the fan belt moves. Best way to do it is by standing next driver seat with door open, helps if your 13 stone plus as it demands a bit of muscle. If you find it is very tight or seized filling the bores with diesel and left for a week can work wonders on sized pistons rings and rusty bores.
I’ll have to admit that I have no means to measure the angle of the threads, 55 vs 60. I use a Starrett thread gauge, and the 16 tpi blade seems to fit the both the OEM and aftermarket bolts equally well. I will note that I checked all of my engineering handbooks and while 3/4-16 is a standard UNF thread form, none of them list that size as a standard Whitworth fastener.
