After moving along with the tool tray and lid restoration I have realised there are two latching devices missing out of the boot/ Trunk door, namely the two pieces that hold the latches shut until you lift the arm, I can see them in some pictures of the boot tool trays, but cannot make out the profile and do not know the dimensions, any body got photos and or dimensions so I can make some
By the way I know the green fabric inside the boot is a lighter coulor, I need need to darken it down to match the tool tray green ( Emerald Green)
Thanks
Mike
The clip is shaped like a letter J. I’ll take one off tomorrow and measure it.
The green felt on the tool tray lid was close but not a perfect match for the green flocking in the tool tray.
Thank you Sir
I was not able to remove the screw because the nut is not captured, would have fallen down inside the lid, and I would have had to remove the tool tray in order to put it back on. So these measurements are taken with the clip in place.
Thanks for that Rob , Much appreciated
