CJ seems to have a nice bit of kit.
Now running 6 inch and long drives, my car is great, any REAL improvement with upgraded sway bars and STOCK bushings and all throughout?
gtjoey1314
I have upgraded/different sway bars for my car. They were on the car before my multi-year refurb and I thought they helped a lot. I have the originals on the car now and thereâs a noticeable difference on how the car feels and behaves in turns. The alternate bars will go back on shortly.
I seem to recall reading many moons ago on the forum about the rear end of the car not really needing a sway bar, or maybe my memory is a little screwed!
I went bone stock as the roads and poly bushes are a bit hard for me
I saw CJ has just an upgrade bar kit
I donât need corners at 6 gâs
Just a teeek maybe
Maybe
I have had a CJ uprated front anti roll bar for years. So long I canât remember what the old one felt like. I hear that IT alone (w/o up rated rear) the car should understeer. Maybe a little, but easily offset with throttle. No downside that I can feel Joe.
Les/Dave what was the fell upgrade
Flatter in turns!
Stiffer?
Not stiffer hopefully
What is it about the stock handling that you want to change? Understeer, oversteer, turn-in, body roll?
Iâd suggest playing around with the easy variables first, like tire pressure, caster, toe and rear roll bar removal as mentioned before you start chasing your tail with aftermarket parts.
First it is a sway bar, then poly bushes, then stiffer torsion bars, then fully adjustable shocks, and before you know it your vintage racing.
Its fine, I liked the all upgrade in my convertable, BUT it changed the feel of the car to a 1990âs car, not an upgraded 60âs car.
My 67 is all new STOCK as you know, but if it makes it a hair more solid or tighterâŚIm game.
gtjoey1314
Flatter Joe. No degradation of ride quality. Still Jag smooth & supple.
Tomorrow I drive all dayâŚlets see which directionâŚI love my smooth ride. Just maybe in turns a hair flatter would be nice
Ill see âŚIjust dont want a hard bottom out feel
My car felt a little stiffer but I was more interested in the flatter cornering they provide. Overall my view is that they were worth doing.
The effects are likely more noticeable in my 2+2 than in the SWB cars.
Yes: a common misconception is that heavy antiroll bars degrade ride quality: they donât.
They will change the under-/oversteer characteristics.
Thanks Guys, after the brake bottle upgrade, will call tomorrow.
gtjoey1314
Many years ago I had gone and replaced all suspension and steering pieces with new. Took the car out for a run on a very twisty mountain road, came back very disappointed. Installed the bar from CJ and once again attacked the same mountain road and came back with a smile on my face, it did the job.
Glenn
As originally configured, the E Type was way soft, in roll.
Unless you enjoy driving over large pot holesâŚ
Thatâs been my experience over the years: increase spring rate to decrease roll, increase anti-roll bars to control the understeer/oversteer. Of course, it is a balancing act along with the tire stiffness, the air pressure, the alignments and weight in the car. But generally stiffer springs give a flatter ride and the roll bars control the steering. IMO.
Just FWIWâŚ
Iâve installed uprated ARBs on almost every car Iâve owned, and usually have added a rear bar if there wasnât one. Iâve never been unhappy with the result. Undeniable improvement, minimal effort. Combined with good tires and shocksâŚand factory spring rates⌠I think uprated ARBs will give most drivers the improvement they are looking for with minimal effort.
I say this with street driving in mind, mild to âspiritedâ. If youâre regularly driving at 9/10ths, or youâre on the race track, a more thoughtful process will be called for.
This conversation comes up all the time in XJS circlesâŚwhich I am more familiar with. Jaguar included/deleted the rear bar several times during the XJSâs 20 year production run.
In an interview Norman Dewis was asked about this. He explained that, after track testing the XJS, he advised superiors that ââŚthe car doesnât need a rear barâ and suggested it could be deleted, without any consumer detriment, as a cost-cutting measure. And, eventually, Jaguar did delete itâŚonly to reinstate it a few years later, then delete it again, etc etc
Over the years many XJS owners have considered adding a rear bar but ultimately declined doing so as a result of Dewisâ remarks. What they fail to recognize is ââŚthe car doesnât need a rear barâ is not the same as âYou should avoid using a rear barâ or âYou wonât like having a rear barâ.
As it turns out many XJS owners do add the rear bar and Iâve yet to hear anyone regret doing soâŚwith the caveat that some aftermarket offerings are simply too large. The factory-spec sizes work well.
The other obvious consideration is that Dewis made his recommendation based on how the car behaved on the track. And we all know that what works well on the track isnât always what works well on the street.
DD
Especially in the case of rear ARBs, bigger is almost always not better.
Well, I submit the knowledge isnât as nearly wide-spread as you and I might surmiseâŚ
Johnny Pseudoracers almost always bollix this up, and then we see mods on street cars that, at best, provide little to no useful benefit, to at worst, make the car less safe/less drivable.
Thatâs what I often refer to as the âmind dyno.â
Most cars have a bit of understeer at the limits. This is considered safer, because the natural instinct when losing control is to turn more and brake more. Which is likely the correct response if the car understeers. By contrast, if the car oversteers, instinctive response would cause a spin. Bigger rear bar increases understeer. Bigger front bar reduces understeer. Itâs not black magic, thereâs a correct rear bar for every front bar and a reason for every handling characteristic.
If only it were that simpleâŚand always correct: itâs not.
Typically, going stiffer on the front bar will increase the likelihood to understeer. And that would be the case in a FWD, RWD, or AWD car. The simple way of thinking about this is that stiffer bar will result in more load transfer to the outside tire in a corner, and take more load off the inside tire. The more load transfer, the less overall grip that axle will have. So a stiffer bar on the front â in relation to the rear â will lead to more understeer; a stiffer bar on the rear will lead towards more oversteer.
This is an extremely complex area, and like pulling the string on a sugar sack, installing/changing a single parameter wonât always result in a single outcome. This is a good âflow chartâ on the general effects of changing suspension parameters.
http://www.morpca.org/drivers-education-guide/understeer-oversteer/
