Perfect ! just what i needed
Steve
Steve
I think you are missing the 2 screws at the front outer corners. Picture of original panel from 1953 car attached shows where they were. Also the hood cable I think showed below the panel originally.
You are absolutely right on the cable - I must have missed it
However, I do not see the front outer corner screws on the photo…
Tadek
Do you have better pictures showing the forward screws you mentioned on the
original panel ?
Click on the picture, then click again and it zooms in.
There are a couple of white arrows pointing to two screw holes.
But they are not at the outer corners, they are more like halfway between the center and outer edges.
Thank you all.
I was not aware of how to zoom in on the picture.
Steve
Thanks - I was wondering where the screw holes are
I will check the corner screw holes when I get back home.
Thanks again for the tip!
