I have a 1971 V12 E-type with a SB engine number suffix. Can
anyone tell me what this denotes as far as the compression
ratio? I thought the SA or SB engines were high compression
and the LA or LB engines were low compression but I am
unsure as to what the exact compression ratio is.
Thanks in advance for the information.–
Steven A. DuChene - XJ6VDP XJ6C XJ12C XK120SE 3.8S E-Types
Phoenix, AZ Atlanta GA, NE Oh, United States
In reply to a message from StevenD57 sent Fri 11 Apr 2014:
Steve:
I thought 1971 was the introductory year for the V12, and
this appeared only in the E type that year, right? The
compression ratio at introduction was 9:1, I believe.
Do you know the production date of the car you have?
In reply to a message from mike90 sent Sat 12 Apr 2014:
Steve:
Evidently, I was recalling correctly. If you look
elsewhere on this site, you will find a copy of the sales
brochure for the 1971 Series 3 V12 E-type, and this lists
the engine compression ratio as 9:1.
SA denotes 9:1 CR. SB is 8:1 CR. The SB engines were for
the US and Canada Markets.–
In reply to a message from Norman LUTZ sent Sun 13 Apr 2014:
Norman Lutz said:-
the US and Canada Markets.<
That is not correct.
The first letter in the suffix denotes compression ratio.
Flat head engine:- S = 9:1, L = 7.8:1
HE engine:- S = 11.5:1, H = 12.5:1
The second letter in the suffix, A or B, denotes
bore/piston grade - differing by 0.001�.–
Roger Bywater / AJ6 Engineering
In reply to a message from RogerBywater sent Thu 24 Apr 2014:
Correct Roger, confused the ‘‘B’’ with the ‘‘L’’ suffix.–
850225/679,1E21003,2W2001BW,JNAEY3AC100218,SAJNV4841KC156072
ROSANNA, Australia
