1994 Jaguar XJ-12 V12-5994cc 6.0L SOHC ref Page 1
Computers and Control Systems: Diagnostic Trouble Code Tests
and Associated Procedures
Code 13
36CU DTC FF13 PCMF MAP SENSOR SIGNAL
This DTC looks for a fluctuating vacuum signal during
starting and monitors vacuum ‘V’ throttle position when the
engine is running.
Code 14
36CU DTC FF14 ENGINE COOLANT TEMPERATURE SENSOR (ECTS) CIRCUIT
This DTC looks for the ETCS signal voltage out of range or
static during engine warm-up.
ref Page 2
Code 16
36CU DTC FF16 INTAKE AIR TEMPERATURE SENSOR (IATS) CIRCUIT
This DTC looks for the IATS out of range.
Code 17
3GCU DTC FF17 THROTTLE POSITION SENSOR (TPS) CIRCUIT
This DTC looks for the TPS signal voltage out of range.
ref Page 3
Code 18
36CU DTC FF18 AND FF19 THROTTLE POSITION SENSOR (TPS)
CALIBRATION
DTC FF18. This DTC looks for low TPS signal voltage at
high load (MAP).
DTC FF19. This DTC looks for high TPS signal voltage at
low load (MAP).
Code 19 ref Page 4
CALIBRATION
high load (MAP).
low load (MAP).
Code 23
36CU DTC FF23 FUEL SUPPLY
This DTC uses the HO2S signal. The feedback integrator
signals (both banks) have been on the rich or lean clamps.
Changes to the mixture have
brought the fuelling back into control. ref Page 5
Code 34
36CU DTC FF34 AND FF36 FUEL INJECTORS (FI)
This DTC uses the HO2S signal. The feedback inegrator has
been on the rich or lean clamp on one bank. Changes to the
mixture have brought the
fuelling on that bank back in control. ref Page 6
Code 36
fuelling on that bank back in control. ref Page 7
Code 44
36CU DTC FF44 AND FF45 HEATED OXYGEN SENSOR HO2S CIRCUIT
DTC FF44 and FF45 monitor the HO2S signal for the correct
output. The feedback integrator on one or both banks has
been on clamp. Changes
to the mixture have produced no response from the HO2S and
the integrator has remained on clamp. ref Page 8
Code 45
the integrator has remained on clamp. ref Page 9
Code 49
36CU DTC FF49 BALLAST RESISTOR CIRCUIT
This DTC monitors that the Ballast Resistor is connected
electrically. ref Page 10
Code 67
36CU DTC FF67 SECONDARY AIR INJECTION SYSTEM (AIR)
This DTC monitors monitors the effect of Air Injection on
the HO2S signal under test conditions. ref Page 11
Code 77
36CU DIC FF77 SPEED SIGNAL FROM PCMI
This DTC detect intermittent loss of the speed signal from
the Ignition System. It will not detect a missing speed
signal on cranking. ref Page 12–
thewytchdoktor=v12 fun!/94 xjs 6 litre/ s=k.log w
Winchester Virginia, United States
