Can anyone help please?–
www.XJ13.eu, C-Type, 95 V12 XJ300 Daimler, XJ13 in-progress
Just a thought, If the only difference is the width of the ring groove, take
the pistons to an engine shop and have them turned wider to fit the 5.3
rings.
Or maybe speak to a good engine rebulding company, they often source rings
based on their dimensions rather than engine make /model…
In reply to a message from Duncan Williamson sent Wed 14 Apr 2010:
You can get rings ground down too, although there might be
other differences and it wouldn’t work for the oil ring
probably.
Maybe a combined approach?
Kirbert
5
probably.
Usually thinner rings are also deeper, I believe.
Modifying either the rings or the pistons would strike me as insane.
I’d put the old rings back in before I’d do either. New rings for a
6.0 simply cannot be that difficult.
– Kirbert
In reply to a message from Dr. Chadbourn Bolles sent Wed 14 Apr 2010:
Thanks Chadbourn and to all who responded privately to my
simple question … ‘‘Anyone know a supplier of standard 6.0
litre piston rings?’’
Looks like I will be sorted soon and I can get back to nailing
another of these engines together - thanks again :)–
In reply to a message from rcarterart sent Wed 14 Apr 2010:
Well, it seems everybodys got an opinoin, so ill add mine,
i would talk to TOTAL SEAL GAPLESS PISTON RING CO. USA. there
engineering is used by some of the best performance vehicles
in the world.
I have used them in a number of engines never had any probs.,
and cylinder sealing is great on comp.tests or leakdown tests,
check web site and make a desicion. and they come with
instructions for install
price is competitive with factory.–
Ronbros
daytona fl. / Austin TX., United States
Kirbert
9
Is there a minimum width for Total Seal rings? If the 6.0 uses
narrower rings than the 5.3, might that mean that the grooves are too
narrow for Total Seal rings?
– Kirbert
In reply to a message from Kirbert sent Thu 15 Apr 2010:
TOTAL SEAL GAPLESS RINGS, are made to an agreed order, talk
to there engineers.
they can come up with a hi-quality ring set.–
Ronbros
