Hi, does anyone know where to get (UK, preferably) a crank
damper/pulley for my '93 XJ12 6.0. According to my local Jag
dealer, these are no longer available new.
TIA, Nat–
'93 XJ12 6.0
Margate, United Kingdom
In reply to a message from Polcon sent Fri 13 Feb 2009:
Nat, damper/pulley is same as 5.3 when they started using the
serpintine belt.
If you cannot get one, I have several, I think extra.
Chadbourn Bolles
803 532 6257
803 798 3044 cell–
Nat. I believe somewhere around 91 or so, for the belt.
Now THERE IS A DIFFERENCE. The 6.0 damper did not use the tapered
cone as the early 5.3 did. I cannot remember what year the 5.3 quit
the cone, but again I think around 91, 92.
There should be a ton of the 91,92,93 5.3 cars around so you should
be able to find one.
Like I said if you cannot, I do have some extras.
Regards
Chadbourn Bolles
803 532 6257
803 798 3044 cell–
Thankyou for that, do you happen to know what year the 5.3 changed
Kirbert
5
Dr. Chadbourn Bolles wrote:
Now THERE IS A DIFFERENCE. The 6.0 damper did not use the tapered cone
OK, so what are the odds that the 6.0 damper will slide right onto
the 5.3 crank where the cone came off?
– Kirbert
Kirbert
8
It will go right on the 5.3 crank.
So it’s not a problem then? Either the late 5.3 damper (w/ cone and
ribbed belt) or the 6.0 damper will work on the late 5.3 w/ ribbed
alt belt?
– Kirbert
In reply to a message from Kirbert sent Sat 14 Feb 2009:
my 94 xji2 eng 6.0 has the cone–
88&86 XJ-S 88 VDP[xj40] 73S1 last&least97xk8
scotts valley ca, United States
In reply to a message from konrads sent Sat 14 Feb 2009:
It may have been a hold over or someone changed it. Every 94 6.0
engine I have seen and built, has not had the cone.
Chadbourn Bolles
803 532 6257
803 798 3044 cell–
