My damper is still in good shape.
I have been looking at it while rebuilding the spare HE engine.
Going off at a tangent to organise a cheaper form of chain tensioner halfway
through the rebuild slowed things down.
The final tensioner parts ordered from the machinist should be delivered
next week and then there is work to make a welding jig.
Hopefully the rebuild kit will be ready about 5 weeks from now.
The HE block has the crank and pistons fitted, but since it is needed to
check the fit of the tensioner kit, the rebuild is in limbo for a while.
It pains me to look at the enormously heavy damper and pulley arrangement.
Lots of weight, gets in the way when working under the front of the engine,
and probably impedes radiator airflow to some extent.
Substituting an electric pump in place of the OEM mechanical one, only 3
belts are needed now, so it might be possible to turn off one belt groove
and get weight down.
More adventurous is the idea of using one multigoove belt to drive
alternator, aircon and PS pump, with a self adjusting adjustor.
That would clean up the front of the engine in a big way
The main problem here is the crankshaft damper. I have a sample mutigroove
pulley and damper from a Holden 3.6 litre V6 engine, which is a GM import
from the U.S. That has much less weight, but the pulley diameter is greater
and that gives more moment of inertia per kg than the Jag item, and it is
( I think ) the moment that more effectively dampens. The GM unit has a
straight bore and keyway which is smaller then the V12 crankshaft, so that
is a challenge. Boring the GM to size is feasible, but slotting for a
keyway is more tricky.
Then again, there is that complicated cone arrangement on the V12
crankshaft. The cone is, or was, no cheap part to manufacture so it must be
there for a reason. I can’t see the reason, so if anybody has a theory let
it rip.
Somebody told me there is a company in Melbourne can rework dampers by
injecting new rubber. I have not had time to follow this up; maybe they
only deal with common dampers they have tooling for, or maybe they can fix
up a one-off with no tooling needed.
If a one-off can be done, then I can cut up the old V12 arrangement and use
the tapered bore and adapt/fabricate other parts to finish up with what is
needed.
A crucial question is how exact is the design of a damper. A web search did
not help much . The best site just showed examples of an undamped
crankshaft mounted between knife edges ringing like crazy when hit with a
hammer, then not ringing when a suitable damper is bolted up to it. Perhaps
the damper is a seat of the pants issue and not designed to a strict
formula. Does anybody know ?
Richard Dowling, Melbourne, Australia, 1979 XJ-S & 1985 XJ6.
