Joost you’re full of ideas! Nothing I love more than a free exchange of ideas
(well, except for actually working on my car).
Oh, and what are you doing with the intake too? I take it that the
stock intake manifold doesn’t accept the tubing from the turbos? Or
do you plan on attaching the tubing to the air filter base?
I’m fabricating my own intake manifolds. I haven’t decided for certain on a
design yet, but I have a pretty good idea. Not 100% from scratch, I’m going
to start with factory manifolds and butcher from there.
Just an idea I had: maybe you could build a complete dual-circuit
turbo system? One turbo on each bank, complete with it’s own
intercooler, then both tubes go to the intake manifold where
they’ll join in a T piece. It might take up less space that way,
plus you could brag about having two intercoolers. If you can mount
two of 'm.
Dual intercoolers have already been figured into the equation, as well as
which intercoolers to use, where to place them, etc. So we’re thinking along
the same lines here. Twin-turbos, twin-intercoolers. There will be a
crossover between banks unless I have a common plenum (have to see… depends
on what I can get away with).
In the book I downloaded from jag-lovers.org, there was a
description of the cooling system. The jag radiator design seems
overly complex. Wouldn’t it be easier / more efficient to have two
(smaller) radiators, one for each bank? Again, there might be
problems with finding the space to mount both of 'm, but if the
space is available, wouldn’t it work better? (perhaps improving the
cooling of the engine, as I learned that the V12 runs quite hot)
No, I’m using a single radiator but my cooling system will be a pretty strong
departure from factory otherwise. I know what I’m going to do, and will post
details once it’s done. Not sure when exactly in the project I’m going to do
the cooling system. Will probably be after the actual motor has been
assembled since certain dimensions may be dependent on where other things are
placed.
-Ted
'82 Jaguar XJ-S – 5.3L V12
