I am going bezerk! I took all of the wraping from
the injector harness to find out that the four wires
from the 3 pin connector that is next to the 8 pin
connector of the FI harness are NOT connected to
ANITHING! Where should they go? I made a diagram of
what I have so far, exept for where those wires from
the other connector go to. I�ll borrow a scanner and
try to post it on the jag lover�s page. If not, then
whoever volunteers a page for it, I�ll send it to you.
Rodrigo Morales
Monterrey Mexico__________________________________________________
Do You Yahoo!?
Yahoo! Photos – now, 100 FREE prints!
ANITHING!
Those wires went to the cold start injectors, which depending on the year
of your car, were removed during the fuel rail recall, or never
fitted. You can safely ignore them.
At a guess they were for the cold start injectors, which were dropped in the
early 1980s because they caused flooding of the engine. The connectors were
a hang-over from these (I guess that Jag had a warehouse full of old
harnesses with the connectors in place but nothing to connect to.
