Hello all
I�m currently in the last throes of restoring a 1988 XJS
V12. Euro spec, High-CR (12,5:1) non-cat HE engine.
I�ve had the engine apart down to the tappet blocks (to make
them oil-tight), had the complete cooling system apart,
radiator out, new waterpump, overhauled all cooling
passages, epansion tank, had the injection apart, changed
all hoses, all fuel hoses, all gaskets (injector, throttle
plate etc), overhauled all wiring, the complete fuel tank,
sump-tank, hoses, filters, the lot. Even eliminated the
half-moon seals., Full overhaul of all chassis rubers,
springs, shocks, gearbox mounts, subframe mounts, radius arms…
In short I went through Mr. Kirbies book from a to z (thank
you VERY much Mr. Kirby).
Now, everything is put back together and after some intial
problems (sticking injectors), the engine is running fine.
It�s oiltight, doesn�t overheat (if I keep the coolant
fiters cleaned) and seems to be running fine on all 12. Has
power, smoothness etc. all is well. Except:
I have a high idle.
With a cold engine as well as with a warm one. When fully
warm the engine idles at about 1100 rpm. It�s not the normal
idle cicuit. I�ve turned the idle control screw fully in,
even if I block the hole in the left air filter where the
aav draws from, the idle does not go down (exept of course
when the engine is cold and the aav is working).
The electrically opened secondary air valve is currently
disconnected, I�v plugged up all vacuum lines except for
those going to the fuel pressure regulators, the gearbox and
the ecu (I�ve even plugged up the connection to the gearbox
for testing while stationary).
I�ve retorqued the nuts on the intake manifolds (new gaskets
under the manifolds of corse, the thick cardbord type).
The only way to get the idle down to about 800 is to block
the PCV. The engine seems to be drawing a lot of air through
the PCV. When I pull that from the left air filter housing
and cover it, the idle goes down. but still not as far as
one would expect. I�ve changed the pvc for a new one
(original jag part $$$), no change.
The other vacuum lines are currently all disconnected, the
distributor vacc advance is currently directly connected to
the butterfly housing (upper connection) so it sees no
advance at idle (but full advance at cruise).
Any help and suggestions would be greatly apreciated.–
Tierfreund
