In reply to a message from PeterCrespin sent Tue 21 Oct 2014:
Pete, Quite obvious you haven’t changed YOUR tensioner
yet. Get back to me after you have. I have a higher
degree in engineering and spent a decade studying material
failures in aircraft. In all those years I have not seen
a poorer design. I’ll repeat…any engineer that uses a
critical plastic part that is prone to failure and buries
it down to the bare block has done a poor job.
Today I planned to pull the water pump, damper, and start
working on the lower oil pans. That plan went south fast.
I broke my 1/2’’ drive breaker bars (2) trying to unscrew
the damper bolt. I then proceeded to break one of my 3/4’’
drive breaker bars before finally loosening the nut with a
1’’ drive breaker. I think I bent the front wing frm
pulling so hard on a 5’ cheater pipe while leaning against
it. That’s tight!
I just had the damper off last year and assumed it would
be easier this time since I used ample anti-seize. The
lesson I get from this Excercise is that anti-seize
obviously lubes the threads so much that the published
torque allows the bolt to thread tighter than planned.
Note to self…if I use anti-seize reduce nstallation
torque accordingly!
4 years ago, when I first got up close and personal with
the front of this engine, I noticed the single posi-screw
holding the water pump…and told myself that ‘‘one day
that screw will frustrate me to no end’’ Today was that
day, and I was not wrong. After bending 2 posi bits and
having no luck with a chisel and punch…it got drilled
out.
So, I have to ask. I assume the posi screw on the water
pump was used originally for clearance. On my car there
is no clearance problem. Did there used to be something
that fouled that bolt hole?
I found the damper last night for $257. That’s the
cheapest I’ve seen after googling the world for 6 hours.
Pete, since you ask, this part is worth maybe $100…on
the outside…based on the pieces that comprise the
complete assembly. The Chinese could no doubt produce it
for less than $25. I will mail the broken pieces for you
to study if you still think I’m out of line. ‘‘Chinsy’’ has
a photo of this damper in the dictionary.–
In reply to a message from CJ95 sent Sun 19 Oct 2014:
Not 100% sure what ‘chinsy’ means. Since it is ‘highway
robbery’ you clearly have deep expertise in the design,
manufacture and inventory/warehousing/cataloging and
service supply of short-run technical plastic components
with a motor manufacturer for models up to forty years
old. What did your own calculations show to be the non-
highway robbery retail price? I’d be interested to compare
the numbers.
If, on the other hand, you were simply voicing an opinion,
then I can do that too. I might think that people who
John. '95 XJS 6.0L convertible. Southlake, TX
