I understand all you say
except not using the timing cover gaskets…are you just
recommending using the 518 with no gaskets?
That’s correct. The problem is that the gaskets and the half moon
seals will NOT work together. A gasket, gortex or otherwise, must be
securely compressed between two metal surfaces in order to seal.
It’ll seal just fine between cover and tappet block, but where the
gasket is over that soft half moon seal it will NOT seal. Typically
it will leak between the gasket and the cover because the half moon
seal is not pressing it up against the cover. You can goop it up and
hope it’ll seal, but that’ll usually only work for a year or two at
best before it starts leaking.
Because both the cover and the tappet block are clean machined parts,
you can seal them together with Loctite 518 and no gasket. It’ll
seal perfectly, and there’s no chance of the gasket getting old or
compressed because it doesn’t exist. It also saves the extortionate
cost of those gaskets. The half moon seal will seal just fine, since
it fills the opening properly and has 518 all around it just to add
belts to the suspenders.
The other idea is to use the aluminum half moon seals, sealing
underneath them with Loctite 518. They provide a rigid surface, so
when the cover is bolted down securely, the gasket is properly
compressed. It’ll never leak. The aluminum plug has to be machined
quite precisely, though, to ensure that the flat surface is flush and
that the round surface fits closely enough to be sealed with the 518.
I was planning to use the posi-seals on the exhaust valves
too, as that is what I used to do with the high
performance Chevy engines. Is it a no-no on the Jags to
use exhaust seals?
I used them, had no problems I was aware of. The argument is that
these seals work so well that the valve stems will run dry and wear.
Just for that, I lubed all the valve guides with dry graphite during
assembly. I have no idea if that really helped, but it seemed to
work fine.
– Kirbert
Visit the Jag Lovers homepage at http://www.jag-lovers.org for exciting services and resources including Photo Albums, Event Diary / Calendar, On Line Books and more !On 28 Oct 2014 at 11:50, CJ95 wrote:
