Ladies and Gents:
I currently have the 6 IDF units on my 1972 E. They certainly add to the
engine compartment but it has been a real challenge to get them tweaked
and I’m now getting about 15-16 mpg. I am considering going back to the
strombergs for simplicity and original look. If I don’t see some further
improvements I’d like to find what would be the best approach to put them
up for sale. My single point experience with ebay wasn’t very fruitful,
even though I didn’t expect a rush to bid on a nuclear magnetic resonance
spectrometer, response was meager (has been donated to a state
university).
If I do sell, I will need the original setup to replace them. I therefore
need some input on what would be the best way to offer these for sale and
the pickup of the replacement stromberg setup. Please respond offlist
Thanks, max
Max,
I have serious doubts that the Stromberg side draft carbs would work
anywhere near as well as the Weber downdrafts on a V12. I would suggest
getting in touch with someone who knows how to properly set them up. Is
your engine otherwise stock? I’ll check my Weber book and see if it has
jetting recommendations for the Jag V12.
Hello max, I have a 73 ots and I have always wanted to try a set of Weber’s. My original stombergs were professionally rebuilt last year and run perfectly. How about a trade. I could remove my entire intake system including carbs, manifolds, cross over pipes, aircleaners, linkage, choke and throttle tower. Every not bolt and grommet to bring you back to stock. You send me your Weber system and when I get tired of playing with it I’ll find someone else with a stock set up who wants to trade. ( The Weber’s are pricey so I should probably send you some money too). Give me a call 757 535 7199
A good while since I’ve posted here. I have done serious modifications to the Weber system including externally adjustable fuel levels eliminating carb top removal The units are now fed fresh air from the front of the car. It has been almost 20 years endeavor to get this thing going. It is currently modified with later HE heads so that it is 11 to 1 compression or so. I have also fitted the Electromotive ignition system. I have also installed oxygen sensors to correctly tune the webers. someone (Michel) recently sent me a private note asking about electronic fuel injection. This obviously is enough of a headache to not even consider efi. Anyone entertaining webers straight up with hot air over the engine is wasting their time. I know, it took me long enough to find out. In The course of doing this I have had two little fires . Fortunately I have a fire extinguisher readily available wherever I go with the car and no damage except for a touch at the vents. Even the quick response is impeded by reaching for the latches and until I get this debugged I run with passenger unlocked. Plan on a CO2 setup as the powder extinguishers make a mess!
Still making final revisions. Had other distractions like working out of state for several years, rear end removal, wheel bearings, the other xke, etc. As good as it sounds it’s still not where I want it and now replacing carb linkages with stainless. My prototype has surface rust so out they go. Also appears I fried the Oxy Gage’s so another pair on order. Plan on mounting above dashboard for continuous fuel viewing. I don’t give up easily but have come close!
