Gentlemen:
My XJS 6.0L V12 convertible is taken off-road for the winter
and I am doing some long-overdue maintenance work. As you
can see in my album, the manifolds came out, new everything
in the ‘vee’ – new gortex cam-cover gaskets, upgraded banjo
bolts/washers, spark plugs, etc. I cleaned all the dirt and
grime with lots of towels (and some gasoline for the hard
spots). I also replaced coolant, T-stats, belts, hoses,
etc. (not related to the subject)
This project has taken me all weekends since November 2011.
The engine has not been started in 2+ months, yet, engine
oil keeps dripping at what (to me) seems a fairly
significant rate � a drop a day. The location of the place
where the oil is coming from is just above the oil drain
plug at the rear of the engine, take a look at:
http://www.jag-lovers.org/v.htm?1329074918
It is above the sump pump gasket level and is brown = engine
oil, not ATF. The other side does not have it. Since I am
yet to start the engine, I don’t know if the leak will get
worse with oil pressure from the pump.
I contacted several JL-members off-list and was advised that
the oil pressure switch and the banjo-bolts are prone to
leaks in this area, but I’ve taken care of that and the rear
of the valley is dry and clean.
Where does the oil come from, I am puzzled? I would like to
address it while I am ‘‘there’’. Can anyone point me in a
direction where I should look for the culprit?
Best regards,
Steve–
'95 XJS V12 6.0L, saphire/tan
