Getting things in order to repair much wiring and connectors in engine compartment, 1994 XJS V12 Convertible.
Trying to source a zip tie assortment with a variety of colors to tag wires, connectors, etc.
The most I can find in any one kit is six colors.
Was thinking there should be something out there with white, black, and seven colors of the visual spectrum at a minimum.
Was wanting to stay away from less robust things like tape or paper stickies, etc.
I use the thin aluminum tags that are attached with thin twist-ties like people use to label their rosebushes. They are waterproof and available very cheap in packs of 50 or 100 on amazon. You can write on them with a ballpoint pen and the writing indents to eliminate worry about ink smudging. Not a perfect solution but better than paper tags.
Jim - when I was doing my telphone work years ago, we used zip ties that had a write-on tab - I think these are still available and in color - check local walmart store for example, or Amazon for zip ties with tag - Tex.
There’s a wide range of straps, markers and ties available on Lazada, Thailand’s answer to Amazon. I have five colours + black and white in various lengths.
I can source and send to you if you need
Will get some of the tabbed zip ties to tag things removed. It seems that these projects have a way of running long and my memory is not as keen as it once was. Thanks.
