Looking to find the locate of the BCM in my X300 (XJ6 VDP)
I’ve found and replaced the ECU, and I’ve found the Transmission module, but can’t seem to find the location of the BCU…
A bit of HELP Please.
Thanks.
Fairly sure its under the tool tray in the engine bay.
I think that I’ve found a photo of the BCM’s location. It seems that it’s inside the cab, and to access it the glove box needs to be removed.
On my 1995 and 1997 XJ6VP, the BPM is behind the glove box. It is mounted vertically. it has one spring pin in the middle, which when pulled outward allows the module to slide downward and out of its bracket quite easily. Then the two multi-plugs can be accessed.
