You all have been such great help, thought I would ask this…
Does anyone know where I can acquire a section of white w/blue strip wire. Need a section that runs from the inner dash area to the ballast located by the coil. Guessing… 6’ section? Dont need an entire 250’ roll.
I needed a long length of white/red wire to add a remote starter button under the bonnet (and maintain correct color code).
I got automotive wire in white from a local store and stretched a long length straight and tight on the workbench (actually it may have been the kitchen counter).
I then used a red marker down the length of the wire to make the stripe. You might experiment with a piece of white wire and a blue marker and see if the results look good enough.
