Ive done it about a month ago and posted some info on
another jag forum… but here is some help if you want to do it:
First off it is very easy!! you do not need to change the
ECU/Computer.
Find a 3.0L , if you want to spend thousands of dollars look
for a jaguar x-type 3.0L, but if you are just like me and
have little cash to spend look for a '03-up FORD LINCOLN LS
3.0L complete engine.( I got mine from Eb@y and paid $100
for a complete Block with super low miles & a extra $100 to
ship )
Keep your old engine until your completely done with the
swap because you will need a few items from it.
Items Needed from old engine:
keep your old wire harness
Oil Pan
Oil Pick-up
the camshaft that controls the water pump
water pump
oil filter mount
a/c braket
Left Head Valve cover
fly wheel
Exhaust Manifolds
Harmonic Balancer
intake
fuel rail
front timing cover
Center Block water outlets/Inlets
thats about it.
Helpful info:
all four Camshafts on the Lincoln engine had same part #'s
Stamped on it as my Jaguar engine.
Sensors( Crank, Cams ) are a Match in #'s
VVT the same
The Lincoln LS 3.0L is a total match with just a few parts
thats different , just keep in mind that the Lincoln engine
was not mounted sidewards as in the Jaguar.
'‘MY’'original post with pictures are posted on :
http://www.jaguarforums.com/forum/showthread.php?p=182571--
Mahalo
