The front lights does not change height when I use the rotating
switch. Ant idea what may be wrong ?–
ekd
Aalesund, Norway
Check fuses and whether you are getting power to the motors. It seems odd
both motors stop working at the same time, but this adjustment doesn’t get
used often by most people so I can imagine the motors/mechanism seizing up.
Can probably free them with penentrating oil and a good clean up though.
Cheers - Jez> The front lights does not change height when I use the rotating
