Hi jag -lovers, was wondering if you could help with strange prob!
near-side front indicator has stopped working on my v8 xjr. checked
lamp and for bad earth. much head scratching. Any ideas, thanks–
llyons
Did you get a reply for this? If you did and this is redundant, I
apologize. If you check for voltage potential at the socket that will
tell you if it is the bulb (some bulbs look good at fail to work). If
you do not have potential then I would expect bad ground, broken wire or
dirty plug.
Jack - '99 XJ8L PA USA
< snip >
llyons
< snip >
