In reply to a message from VIP Emporium sent Mon 21 Apr 2008:
Well, call off the search…haha. Thanks to the forums, even
though no one came to my rescue…well not directly anyhow.
I’d like to thank member ‘‘JEGUAR’’ for this post he made back
in September of 2005:
''A few days ago, I noticed that the reverse lamps were not
working on my car. The tail lights, turn indicators and
licence plate lamps were working just fine, and the ‘‘bulb
failure’’ light did NOT go on.
Back home, I quickly found that the stop lights and the fog
lights were not working either. I must have been lucky to
not be rear-ended!
All bulbs were good. It took several hours of signal
tracking and testing to finally isolate the problem: there
was no power coming on pin 17 of the ‘‘rear lighting control
module’’.
The fuse #14 in the right hand heelboard fuse box was
burned. This fuse controls power distribution to a bunch of
things (ancillaries, etc.)
I can’t explain why some lights controled by the same module
were working and others not, nor why the ‘‘bulb failure’’
warning didn’t go on (the stop and reverse lights are in the
same circuit in the module, but not the fog lights…)
I hope that this post can save time to someone later.
Best,–
Jean-Eric G. ‘89 XJ40 3.6 l VDP (US), ‘95 X300 3.2 l (Fr)’’
And yes…it has saved me time…and money! Although I have
a Vanden Plas LWB car so that particular fuse box is under
the back passenger (LHD) seat, but the fuse number was the
same. I hadn’t had though of checking it since it listed to
have nothing to do with the lighting. How odd. I am SO
relieved!! Thanks JagLovers!!! So happy I could
donate…it’s now bitter sweet!
Haha…yet again replying to myself. After some random
searching I found this:
‘‘The stop, reversing and rear fog lamps are controlled by the
security and locking module (SLM), which receives inputs via the
SCP network from the BPM’’
Interesting…is this in the X300 and the X308? Or X308 only??
Vanden Plas VIP
Vanden Plas VIP
