Hi all.
I am thinking about buying an OBD 2 tool for my jaguar x300.
Does anyone know if they are suitable for these cars.
Mine is a 1995 3.2 (Sov)
Straight 6.
UK spec.
Thanks
Rob–
Rob Evans
In reply to a message from Rob Evans sent Thu 27 Mar 2008:
Rob,
Yes, your car can use an OBD2 reader/scanner.Big difference
between the simple readers and the latest scan tools like
AutoEnginuity.Which do you want?–
95 XJR, 69 E-Type ots ,97 Miata ,‘X’-type SUV
Sierra Madre Ca 91024, United States
In reply to a message from anthony davenport sent Thu 27 Mar 2008:
I recently bought this one:
http://www.webshop.luccio.nl/OBD2USB_Scantool__E_art_13.html
Works very well on my 1996 XJ12.
(not affiliated with them in any way)–
henkreyn
Hi, I have also been thinking about one of these, especialy one
which connects to a laptop so you can see whats going on as the car
is driven. Can any of these units be used to adjust the timing /
fuel mixture ect and then test drive watching the sensor outputs?
John–
JohnXJR
Lancashire, United Kingdom
In reply to a message from JohnXJR sent Sat 29 Mar 2008:
Well, mine can’t adjust things, but you can watch, the Sensor
outputs while driving–
John
henkreyn
John,
If you check the archives there were several Listers a month
ago that were buying the AutoEnginuity. You might email them
and ask how it worked & let us all know your synopsis?
A simple code reader is only about $50 here but it is much
too limited to help with the real problems.If notice the
problems on this forum ,many are idle/misfire/no
start/driveability. If the owners of those cars were able to
post a comprehensive scan along with their symptoms I
speculate we could diagnose the exact problem and avoid
wasting money on needless parts and needless mechanic time.
It all depends how useful the AutoEnginuity software is.
That question is better answered by those who recently
bought it(540 touring?)than by the marketing hyperbole on
the AutoEnginuity website. If it works well,it would pay for
itself by saving us much money and time.–
John
In reply to a message from anthony davenport sent Sun 30 Mar 2008:
This will sound like heresy, so read on…I have been running an
XJ6 for 7 years now and have a ProScan laptop scanner and a cheap
Pep Boys code reader. I use the code reader all the time, but have
yet to use the scanner. In reality, there are few instances when
the scanner is needed. The primary one is mixture analysis. Until
the mixture gets haywire, the scanner is not of much value. The ECU
will set codes quick enough to analyze problems. I recently had a
misfire detection on #4 cylinder that led me to a bad fuel injector
at minimum pulse width only, but required analysis in addition to
the code to find the solution. The scanner would not have done any
better. So before getting out there, you might start with a code
reader and see how far it gets you.–
Brian Caro 96XJ6 4.0 63E-TypeS1FHC 05 XJ8 4.2
Newport News, VA, United States
you can try this one ALLSCANNER VXDIAG A3, it Support BMW LAND ROVER & JAGUAR and VW can replace bmw icom & 5054a & JLR,I have got it from chinacardiags.com
Tuita, FYI this post was from 11 years ago, I think the original poster is probably set now.
