I had my auto enginuity OBD scanner hooked up to my 2003XJR
and up popped P1517.
So I’ve been checking on the JTIS documentation what this
could be. Could be related to the transmission rotary switch
and or gear selector cable settings.
Still, engine starts fine. So not sure whether I should do
anything else. The last thing I want is my car failing to
start, because that tends to happen at the most inconvenient
moments.
I’m looking at the JTIS information and I dont see any
specific diagnostics section for this particular P code.
There’s a section about how to adjust the gear selector
cable. Can’t find that rotary switch anywhere. JTIS mentions
a linear and a brake switch, but where’s the rotary switch.
If I look at the P1517 it could be as simple as high
resistance in this switch. Depending on where this switch
sits and what it looks like that might be solvable with a
blast of electro cleaner.
In reply to a message from mikedefender sent Thu 31 May 2012:
Already tried that. Keeps coming back and it keeps starting fine!
So either I don’t worry, or I figure out some course of action.
Jeroen–
Erase it and check it again. Sometimes an error it’s not real.
In reply to a message from JeroenD sent Thu 31 May 2012:
Jeroen, don’t know if this will help but these are the
Jaguar specific DTC’s not the Generic.
P1500 Vehicle Speed Sensor Intermittent
P1501 Vehicle Speed Sensor Out Of Self Test Range
P1502 Vehicle Speed Sensor Intermittent Malfunction
P1503 Auxillary Speed Sensor Fault
P1504 Idle Air Control Circuit Malfunction
P1505 Idle Air Control System At Adaptive Clip
P1506 Idle Air Control Overspeed Error
P1507 Idle Air Control Underspeed Error
P1508 Idle Control System Circuit Open
P1509 Idle Control System Circuit Shorted
P1510 Idle Signal Circuit Malfunction
P1511 Idle Switch (Electric Control Throttle) Circuit
Malfunction
P1512 Intake Manifold Runner Control (Bank 1) Stuck Closed
P1513 Intake Manifold Runner Control (Bank 2) Stuck Closed
P1514 High Load Neutral/Drive Fault
P1515 Electric Current Circuit Malfunction
P1516 IMRC Input Error (Bank 1)
P1517 IMRC Input Error (Bank 2)
P1518 Intake Manifold Runner Control (Stuck Open)
P1519 Intake Manifold Runner Control (Stuck Closed)
P1520 Intake Manifold Runner Control Circuit Malfunction
P1521 Variable Intake Solenoid #1 Circuit Malfunction
P1522 Variable Intake Solenoid #2 Circuit Malfunction
P1523 IVC Solenoid Circuit Malfunction
P1524 Variable Intake Solenoid System
P1525 Air Bypass Valve System
P1526 Air Bypass System
P1527 Accelerate Warmup Solenoid Circuit Malfunction
P1528 Subsidiary Throttle Valve Solenoid Circuit Malfunction
P1529 SCAIR Solenoid Circuit Malfunction
P1530 A/C Clutch Circuit Malfunction
P1531 Invalid Test - Accelerator Pedal Movement
P1532 IMCC Circuit Malfunction, Bank B
P1533 AAI Circuit Malfunction
P1534 Inertia Switch Activated
P1535 Blower Fan Speed Circuit Range/Performance
P1536 Parking Brake Switch Circuit Failure
P1537 Intake Manifold Runner Control (Bank 1) Stuck Open
P1538 Intake Manifold Runner Control (Bank 2) Stuck Open
P1539 Power To A/C Clutch Circuit Overcurrent
P1540 Air Bypass Valve Circuit Malfunction
P1549 IMCC Circuit Malfunction, Bank B
P1550 PSPS Out Of Self Test Range
P1565 Speed Control Command Switch Out of Range High
P1566 Speed Control Command Switch Out of Range Low
P1567 Speed Control Output Circuit Continuity
P1568 Speed Control Unable to Hold Speed
P1571 Brake Switch Malfunction
P1572 Brake Pedal Switch Circuit Malfunction
P1573 Throttle Position Not Available
P1574 Throttle Position Sensor Disagreement btwn Sensors
P1575 Pedal Position Out of Self Test Range
P1576 Pedal Position Not Available
P1577 Pedal Position Sensor Disagreement btwn Sensors
P1578 ETC Power Less Than Demand
P1579 ETC In Power Limiting Mode
P1580 Electronic Throttle Monitor PCM Override
P1581 Electronic Throttle Monitor Malfunction
P1582 Electronic Throttle Monitor Data Available
P1583 Electronic Throttle Monitor Cruise Disable
P1584 TCU Detected IPE Circuit Malfunction
P1585 Throttle Control Unit Malfunction
P1586 Throttle Control Unit Throttle Position Malfunction
P1587 Throttle Control Unit Modulated Command Malfunction
P1588 Throttle Control Unit Detected Loss of Return Spring
P1589 TCU Unable To Control Desired Throttle Angle–
Jeroen
In reply to a message from Neil Maldon sent Fri 1 Jun 2012:
Hm, I’ll need to look into this some more. I’ll probably post a
question on this OBDII forum. Seems there are different sets of
Jaguar specific code floating around.
I’m pretty sure some of them are type specific. When looking up the
DTC’s on the JTIS CD you do need to specify type and year of your
car.
So it might be as simple as that. If not I’ll have to dig a bit
deeper, because I wasn’t aware my XJR had a ‘‘IMRC Intake Manifold
Runner Control’’. It might, but I haven’t come across it yet.
I’m visiting the Jaguar dealer tomorrow. They’ve invited me for a
free-inspection. Being Dutch, I never pass on anything free. And
they have 10 iPads they’ll be handing out as well. Let’s see what
comes out of this.
Actually, it was the free inspection that prompted me to hook my
XJR up to my own OBD analyser. It’s all very well having a Jaguar
specialist figuring this out for free, but I want to make sure I
understand it myself. My car has always shown a few other (U) codes
as well. Never seem to do any harm. lets see what the specialist
says.
After the visit to the Jaguar dealer I’m taking the bumper of for
its respray, see my other post.
So I’m looking forward to an enjoyable Saturday, fiddling with my
car.
In reply to a message from JeroenD sent Fri 1 Jun 2012:
The JTIS codes for a specific model and MY should always
trump the general codes.
And Jeroen- If your dealer ‘‘friend’’ can’t find at least a
1000 euro or so of work you need, I would be suspicious of
him not being very good at his trade.–
Ross - 89 XJS, 98 XJR, 99 XJR, 02 XJ8
In reply to a message from sparkenzap sent Fri 1 Jun 2012:
Yes, they should, but here we have a case where we have a
specific code ie PS1517 that appears to have two different
meanings. So I’m thinking there are Jaguar specific codes
per model/year.
$1000,-- at an official Jaguar dealer doesn’t get you much
is my experience.–
So I had the dealer free check this morning. Came through
with flying colors!
I did check the codes with the mechanic. My definition for
P1517 as I found on my JTIS and as published on this site
were correct. No idea why this ODB site shows something
different, but it is incorrect!
