i have a jaguar xj6 1995 in singapore.
The car come without a key fob
Central locking is not working
Trunk switch not working
the doors and trunks do open by key but one by one only.
i did a relay test the central locking works when I activate
the central locking and opening relay
i think that the security control unit is not working but I
am not sure sense I don’t now ho to test the unit
my security unit has part number LNA 2600 BC/002 I am
looking for a used part, can I buy a unit with a different
part number example LNA 2600 cc /xxx
pls need help solving this–
Hafid
Hafid, are you saying that the key will not centrally lock and unlock
the car? - see the handbook.
Fobs can be obtained on eBay:
The trunk switch is probably not working because some wires in the RH
trunk hinge loom have broken - very common problem.
HTH
Chris C
Hafid wrote:> Hello,
