has anyone played with the torque on the upper bolts of the front shocks? I couldn’t find specs for the '97XJ6 so I used the settings for the '93 XJ6 that I used to own. 20 ft/lbs. 20 ft/lbs is a lot of torque on those rubber bushings and it appeared to me, as I kept re-adjusting to get them to the ‘proper’ torque that the ‘crash’ got worse. Getting a torque wrench onto that bolt, while holding the nut with a hex wrench (Bilstein design) called for an crowsfoot attachment. I was never certain that I was getting accurate readings with that offset that the crowsfoot introduces.
I put Bilsteins on the front. The ‘crash’ is there but the cornering is definitely improved over the original equipment.
Ken Fink
Ann Arbor, MI
97 XJ6, 70,000 miles-----Original Message-----
From: owner-x300@jag-lovers.org [mailto:owner-x300@jag-lovers.org]On
Behalf Of Scaredycat
Sent: Thursday, December 16, 2004 11:05 AM
To: x300@jag-lovers.org
Subject: RE: [x300] So where’s the luxury ride . . . ?
In reply to a message from jaguarSean sent Thu 16 Dec 2004:
Wow. Lotta info here. I work at a Porsche dealer, that just
bought -out a jaguar dealership. As a result, we see a
lotta ‘‘older’’ jags 95 on up. I took the plunge, in a moment of
weakeness, and purchased a lady-driven(whatever that means), 82,000
mi, delaer maintained 97 XJ6L, and at first, I wasnt to impressed
with the ride. I had that ‘‘crash’’ you guys describe, but a new set
of front shock bushings cured it.
About the ride though, I always thought that the ride of an XJ was
like a cross between the early 90’s bmw and a cadillac deville,
Taust- but never stiff. I wouldnt call it a ‘‘handler’’ though, but
were used to Porsche. The 97 came in as a trade on a Pcar.
Last month, we another couple came through here With a 95 XJ6. OF
course, I had a look, drove it over the weekend, and bought it.
Its a short wheelbase car with 100K, dealer maintained, etc, etc
With a set of goodyear eagle Regatta tires,Which somehow I think
are very similiar to the P4000’s recommened, and the 95, with
higher miles, and shorter wheelbase, rides nicer than the 97,
making me think the Tires have a lot of influence in the ride.
Except the 95 has the ‘‘crash’’ also, but only on the right side,
took it in to have the bushings replaced, the dealer said they
didnt need it, and replaced the Radiatoer mounts instead, and its
still ‘‘crashing’’ Just dropped it off this morning. If its not the
bushings, could it be the Dampers/shocks? Sometimes, over certian
types of bumps, it feel like, im hitting the Bump stops, even on
relatively minor bumbs, and making right hand turn on inclination
like drive ways? Any Ideas?
Thanks
BTW I’ve been lurking here for a long time. I appreaciate all of
the info here. My name came from the fact that I was afraid to
purchase an old jag, because Im not rich, the info I found here
helped me to pull the trigger on the first jag, and I have really,
really, enjoyed it. So thank you guys.
Bill Swanson
Porsche salesman(14+ yrs)
Jaguar driver
Scaredycat
