I was wondering if any one has a template for a camshaft timing
tool. I do not have access to one and I can imagine that ordering
one from Jaguar will be costly. I dont believe making one would be
difficult at all.
Thanks
Mike O–
Mike O’Connor 89XJS V12 Coupe 1995 XJ6 VP
Derby NY, United States
Mike,
Look on ebay under “Car & Truck Parts”. Just type Jaguar in the
search. There’s usually one listed there or any of our “usual suspects”
stock them for under $10 if I recall.
Earl Kiker
Hi Mike,
if you are a member of the Jaguar Enthusiasts Club, you can order one
for 25.53 UKP plus p&p plus local taxes.
http://www.jec.org.uk/sptools.htm
HTH
Chris C
Mike O’Connor wrote:> I was wondering if any one has a template for a camshaft timing
difficult at all.
Thanks
Mike OMike O’Connor 89XJS V12 Coupe 1995 XJ6 VP
In reply to a message from Mike O’Connor sent Mon 17 Apr 2006:
Hi Mike,
There’s a cam tool on ebay at the moment at 9.99 GBP
Best Regards,
Mike
1996 X300 3.2L–
difficult at all.
Mick83
Sorry mike,forgot to add item no. - 4630627101
Mike–
difficult at all.
Mick83
In reply to a message from Chris Copplestone sent Mon 17 Apr 2006:
From the JEC site it would appear that the X300 6 cyl
camshaft setting tool is the same as the XJ40 - part # 18G1433A.
That being so, can I suggest an alternative which can be
made from this template. It has the advantage of holding
both camshafts at TDC #1 cylinder at the same time.
http://www.jag-lovers.org/snaps/snap_view.php3?id=1086870471--
HTH
Chris C
Mike O’Connor wrote:I was wondering if any one has a template for a camshaft timing
difficult at all.
Bryan N, '91 Sovereign 4.0 L, (RHD)
Cambridge, United Kingdom
In reply to a message from Bryan N sent Mon 17 Apr 2006:
Thanks to all who replied an a special thanks to Bryan N who came
through with the template.
Mike OConnor–
