First, sorry to ask this because I’m certain the info is on
here somewhere. But, I have now looked at so many threads
that they’re starting to blur together and I still can’t
seem to find the information I think I need.
Here’s the problem: '96 4.0 VDP. No problems at all, then
it just wouldn’t start one morning. I turns over freely,
but it just refuses to even attempt to fire.
I have checked and swapped the fuel pump relay. I have
confirmed that the fuel pump is at least providing some
pressure as I can hear it engage, and when I barely cracked
open the line between the pressure regulator and the fuel
rail, it spewed a nice, fine stream of gasoline.
The car will fire and run for a second or two with a shot or
two of starting fluid, so I know I’m getting spark and
timing. That seems to rule out crank or camshaft position
sensors.
Therefore, since there is fuel in the fuel rail that is
apparently not getting into the cylinders, I believe I have
some issue that is keeping the injectors from firing. I
have seem numerous suggestions in similar cases to check
that they are getting a signal, but I don’t know how to do
that. Some have suggested a test light is insufficient
because of the small amount of voltage and the brief period.
And anyway, I am at this point fairly certain that the
injectors are not getting the proper signal based on the
other tests.
So, IF the injectors are not firing, THEN what should I look
at next? Is there yet another relay or fuse hiding
somewhere besides the obvious that might cause such a
problem? I have one book that shows an injector relay
behind the right headlight, but it says that is only on the
V12. For the 4.0, it says it’s an ‘‘ECM Controlled Relay.’’
Nonetheless, I have swapped it with another close by to no
effect. (I have FINALLY ordered my repair CD’s, but they
may be in the mail for a few days.)
Thanks to EVERYONE for ANY suggestions at this point. I’m
going to go scratch my head now and keep thinking.–
'96 VDP 4.0, '95 XJ6 4.0, and '96 XJS 4.0
Dallas, Texas, United States
