A club member is having this issue. He also had problems with locking, remote, boot opener etc. which turned out to be a blown Security System fuse (F4) in the boot.
The car was working up until he wanted to investigate a slight misfiring upon regular driving. (He did find a crack in the frontmost coil/sparkplug cap which he ‘remedied’ with a shrink-tube.
After putting everything back together, the car would not start. It cranks but will not fire. All fuses checked (even a selection in the rear compartment has been checked.)
Any wisdom on this? I know I have been faced with this before but cannot remember what the culprit was.
Not sure where you are based and if the car has an immobiliser, but does the check engine light come on an turn off after a while when the igintion is switched on (withough cranking)?
