Cannara wrote:
Just for fun, I went out to our SIII with an oscilloscope & multimeter.
Here’s what we have:
“Lucas Super” coil with about 1.5 Ohms primary resistance. It says on it, in
a couple of languages: “Use only with 1.3-1.8 Ohm ballast resistor”.
A 1-Ohm ballast screwed to one terminal.
The amp wires go to the remaining coil terminal and the remaining ballast
terminal (the wht/blk amp wire and the tach and ECU wires, tan/grn & tan/blk,
go to one coil term, the wht amp wire and yellow ignition wire to the other).
> With my scope, I could see that the ballast drops about 1.5V max. Since it's
> a 1 Ohm resistor, this means it's passing 1.5A max. The average current on
> the meter is about 1.2 into the amp. The waveform across amp shows a max of
> 1.5V, so it too looks like about 1 Ohm when on (charging the coil), which is
> analogous to point closure.
> So, I agree that we likely need no ballast on EI XJs.
And I do so agree with you, Alex!
However, just to be pedantic, too! You measured the system dynamically,
where most of the systems resistance comes from the coil’s impedance.
While irrelevant for the “constant energy” system, but relevant for
“Opus” and straight points systems: On a stationary engine current is
primarily limited by the coil-and-resistor ohmic resistance. With your
data to some 5 amps. Increasing to 8 amps if you remove the resistor.
As some of us may run aftermarket ignition systems with unknown
characteristics some care must be taken, even if, as I agree, this is
immaterial to the 4,2 SIII’s normal system.
Incidentally, removing your external resistor will naturally increase
current flow, and thus ign “power”. Probably to some 2+ amps dynamic,
which can easily be checked with an amp meter. And still is well within
the capacity of the coil and amplifier.
Which is a test anybody can do, static or dynamic if in doubt?
Frank
xj6 85 Sov Europe (UK/NZ) - without external resistor :-)===================================================
