Fuel injection hose is fine…but I think it’s 1/4", actually.
The throttle body should have two coolant hoses. As I recall, one comes down
from the water rail and the other from the water pump area as you mentioned.
If the nipples come out of the throttle body…they often do…just clean
the area and use JB Weld to glue 'em back in. No need to remove the t/body
to change the hoses.
Doug Dwyer
Longview Washington USA
1995 XJRFrom: “Ken Davis” ken@azkiwis.com
Leading from the water to pump to “Somewhere” around the throttle body is
a small hose, looks to be 5/16 or so.
The question: – where does it terminate on the throttle body, and what
has to be removed from TB in order to change it, and, will FI hose work
here?
Ken> Fuel injection hose is fine…but I think it’s 1/4", actually.
down from the water rail and the other from the water pump area as you
mentioned.
clean the area and use JB Weld to glue 'em back in. No need to remove the
t/body to change the hoses.
