The Fog lamp switch requires very little modification to go into Fog
position. To get to Fog you need to be able to push the switch in, and then
turn to Fog position. What is keeping you from being able to push the switch
in is a simple c-clip (or e-clip) on the switch shaft. Merely lower the
switch from the dash panel and look at the shaft. You will see this small
(about 1/4 inch diameter) clip on the shaft. Remove it and you now have the
ability to provide voltage to your Fog Lamp wires. Understand, at least on
the Series 3, that when you put your Fog Lamps on, your Head lamps turn off.
Regarding mounting, I have a 1987 Series 3, which also had holes in the
valence, but which looked way to low for fog lamp mounting. There are
brackets you can get from Jaguar, $16.00 US each, for mounting to the Series
3 bumper underside. I’m sorry, my experience with the Series 2 is limited to
a test drive of a 1976 XJ12C long, long ago.
Dennis-----Original Message-----
From: owner-xj@jag-lovers.org [mailto:owner-xj@jag-lovers.org]On Behalf
Of Dave Spalding
Sent: Friday, May 07, 1999 9:57 AM
To: XJ LIST
Subject: Re: [xj] FOG LIGHTS?
If the archives were available, I’d send you there…but:
My understanding is that on the European SII the running/signal lights are
in the front valence. The U.S. SII has the turn signals in the bumper, so
the holes in valence are unused except as a way for the wires to get to the
lamps.
The light switch was common to both models and on U.S. spec cars does not go
to the FOG position. I think someone out there on the list has taken the
switch apart and modified it. Maybe that person can reiterate the
procedure.
Dave Spalding
79 XJ6L
Date: 5/7/99 12:10 PM
To: Spalding, Dave
Could someone enlighten me?
On my 76 XJ12L there are two holes drilled (cut) in the front skid panel
(under front bumper). I would presume that this is where the stock fog
lights were mounted originally. Can anyone confirm if this is accurate
AND/OR could someone accurately tell me where the lights should be mounted
and what were original lights (Manufacturer, size, candle power, etc.)
Question 2: How does this all function. Does the fogs shut off when the
high beams are activated? Dot he fogs work at the same time with the
parking lights, the driving lights (low beam) or both or neither?
Also, the dash light switch has a setting for FOG, but the switch does not
go there. Seems I heard about someone doing something to one of these
switches to make it work?
TIA
J. Rick Smith of G.S.I. Investigations�
ICQ: 35075011 ’ AIM: Us in Phx
http://www.messaging.airtouch.com/paging/sendpage.html
and place in pager number 602-408-3992 and you can send a text message
directly to me/
------------------ RFC822 Header Follows ------------------
Received: by quickmail.yale.edu with ADMIN;7 May 1999 12:06:01 -0400
Received: from lyons.jag-lovers.org (lyons.jag-lovers.org [193.69.225.15])
by mail-relay3.its.yale.edu (8.8.8/8.8.8) with ESMTP id MAA27055
for david.spalding@yale.edu; Fri, 7 May 1999 12:04:38 -0400 (EDT)
Received: (from )
by lyons.jag-lovers.org (8.9.1/8.9.1/Jag-Lovers/3.6/GH)
id RAA10037-owner-xj@jag-lovers.org for xj-out;
Fri, 7 May 1999 17:38:01 +0200 (CEST)
Received: from mtiwmhc01.worldnet.att.net [204.127.131.36] (HELO
mtiwmhc01.worldnet.att.net)
by lyons.jag-lovers.org (8.9.1/8.9.1/Jag-Lovers/3.6/GH) via ESMTP
id RAA10033-J.RickSmith@worldnet.att.net for xj@jag-lovers.org;
Fri, 7 May 1999 17:37:59 +0200 (CEST)
Received: from jrs ([12.72.33.41]) by mtiwmhc01.worldnet.att.net
(InterMail v03.02.07 118 124) with SMTP
id 19990507153726.CFVQ19064@jrs for xj@jag-lovers.org;
Fri, 7 May 1999 15:37:26 +0000
Message-ID: 001d01be989f$b2c92020$2921480c@jrs
From: “=?iso-8859-1?Q?J._Rick_Smith=2C_G.S.I._Investigations=AE?=”
j3044a@Worldnet.att.net
To: xj@jag-lovers.org
Subject: [xj] FOG LIGHTS?
Date: Fri, 7 May 1999 08:38:45 -0700
MIME-Version: 1.0
Content-Type: text/plain;
charset=“iso-8859-1”
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 5.00.2014.211
X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2014.211
Sender: owner-xj@jag-lovers.org
Precedence: bulk
Content-Transfer-Encoding: quoted-printable
X-MIME-Autoconverted: from 8bit to quoted-printable by
mail-relay3.its.yale.edu id MAA27055
