From the Vehicle Maintenance Sheet (JLM 10 51 02/021) for Series III VIN
Range 300001 - 500000
Which is the entire range of Ser III production, not a selected segment
of it
at 7500 mile and 15000 mile intervals; Grease all points (excluding hubs)
at 60000 mile intervals; Remove clean and inspect front wheel bearings
(replace bearing if required and the oil seals)
As opposed the earlier recommendation of 30k intervals for hub bearing
greasing
I had a bearing fail and so checked with my Jaguar dealership and they
advised this VIN range was fitted “sealed for life” units
Hmmm. I don’t expect mine to be taken as the final word on anything but I’ve
never seen a sealed bearing anywhere on a Ser III
because it was found greasing via the nipples didn’t improve the life of
the bearing.
Which is believable
For older models
Which models, I wonder, are they referring to ?
so long as the bearing was correctly packed on fitting it should last at
least as long as the fronts probably twice as long, they did say make sure
the dust cap is in >place as water getting in there was usually the cause
of failed bearings.
And make sure the hub seals are good…to keep grease in and everything else
out. I attribute the long life to the generous size of the rear bearings
more than anything else, but that’s just me.
Most engineers recommend that upon inspecting the fronts it would do no
harm to inspect the rears.
So long as “inspecting” the rears means a wiggle test for excessive free
play. Anything more requires a tear down as far as I can tell…not
something to be taken lightly on a rear hub !
Any bearings replace by the dealership are automatically fitted with the
“sealed for life” units and new dust caps, the grease nipples are left in
place to keep the >moisture out.
There are no nipples on the rear hubs, so they must be taking about the
fronts…and I love to hear more about the sealed bearings being
mentioned. Can you/they elaborate? I’d think a sealed bearing would require
a different hub arrangement entirely.
Doug Dwyer
Longview Washington USA
1995 XJRFrom: “BARRIE DAWSON” barrie.peter@btinternet.com
