AFIAK, before cranking in the ignition position, on constantly.
With engine just started, it should extinguish after a couple seconds.
If your engine chokes, stumbles, misfires badly, it will illuminate. For
example, idle drops below normal ranges (been there).
If you lose power while driving, i.e. ignition amp dies, it will illuminate
(been there).
I’m wagering a guess that if your charging system or coil fails/falls below
norm voltage, it would illuminate?
Can anyone else add to this list?
Sunny
'97 XJ6 Anthracite
'76 XJ12L Sable
Original Message:-----------------
Date: Tue, 30 Jul 2002 20:12:44 EDT
To: xj@jag-lovers.org
Subject: [xj] Ignition Light
At what times should this light be on at normal circumstances? We have…
Lock Accessory Ignition and Start.
This is an XJ-12, 76
Thanks
John
http://www.jag-lovers.org/cgi-bin/majordomo.
mail2web - Check your email from the web at
http://mail2web.com/ .
