Tim wrote <<1. Got rid of the original coil. I felt, since it was stock,
it was
probably going to die on me at the worst time possible.
2. Purchased a “Mallory” 40K volt. coil (chrome) via the internet.
(sorry, can’t find the receipt).
3. Used the ballast resistor they recommended for a small additional
charge. ($8.00 us)
4. Mounted the new coil vertically on the fender right up closed where
the fender and radiator meet.>>
Hi Tim, I recently had a coil problem myself. While driving the engine just
died. Upon inspection along side I75 I noticed the wire going to the
positive side of the coil was burned in two. This coil was the original coil
that came on this engine when I bought it. It did have the Jaguar logo on it
and also said “To be used with external ballast resistor.” My car had no
visible ballast resistor as some I have seen. My old engine was the same
way. Luckily I had a DVM and a few tools with me. This coil was shorted to
the case. Apparently no ballast resistor exists anywhere. If so it wouldn’t
have burned the wire up. I removed the coil, wrapped it in electrical tape
and remounted it to make sure the case was not grounded. After that, I
restored voltage to the coil with a jumper lead. The car started right up
and I drove to the nearest parts store and got a coil they listed for the car
which had the same warning about the ballast resistor. Since installing the
car runs fine, but this just can’t be right. I guess it is possible it could
be ballasted on the ignition amp side but I don’t think so. This brings two
things to mind. Why did Jaguar put a coil on the car made for a ballast
resistor when there is no resistor? No wonder they give so much trouble.
Why did they use a mounting system that grounds to the engine with a metal
case coil? Any short to ground results in burning up the wiring. I’ve yet
to do anything about it, but I plan to at least provide some insulation
between the coil and the mount with a large piece of heat shrink tubing
around the coil. I assume Jaguar left out the ballast resistor to get a
higher spark voltage. It sounds like your fix to go to a higher voltage
ballasted coil may be the way to go.
Steve R
85XJ6
