Max,
Please use the good tank while you remove the leaking tank and let it air out for a bit. A
good reason not to just keep driving on one tank is what do you do if the other tank springs
a leak. Get both of them working well and enjoy the car.
After you let it air out for a while, are there any radiator or other tank type shops in your
area? You could find a like new used version here in the states and ship it to Oz for that
kind of money, so what they are proposing will make them very happy by paying the rent for
the month.
Hopefully some other Jag people from Oz will chime in and give you some parts sources
but $1000 AU is a bit much unless the tank is lined with gold.
Try looking here: http://tiny.cc/OgN9z $400 USD and you could ship to Australia and still
be almost half price of what the dealer is trying to charge. I would look around where you
live for a better deal. Starting with a normal mechanic and not the dealer.
JoeOn 30 Apr 2008 at 12:36, Max701 wrote:
Hi Everyone,
The fuel leak out of the left hand tank of my 1983 XJ6 Vanden Plas
has now become so significant is is a potential hazard.My dealer has suggested removal and reconditioning at a total of
around $1000 Australian Dollars.Am finally wondering if the money I spend on this car is reaching a
point of negative return, so was therefore wanting to ask if anyone
knows if it is possible simply to drain the tank, leave it be and
in future run the car solely on the right hand tank?Any suggestions would be greatly appreciated.
Kind regards,
Max Renouf
