I’m confused about the right procedure to measure and correct end-
float when re-assembling the rear hub and carrier. The manuals
(collectively) have two procedures. One is with the assembly off
the car and on the bench. The other is with the unit on the car.
I understand checking the end-float after the unit is installed.
Any adjustment is made by obtaining the proper thickness bronze
spacer that is installed behind the hub carrier.
But why is there an end-float check with the assembly off the car
and on the bench? Why not just wait until it’s all on the car and
check it there?
The reason I am asking is I have taken the hub/carrier assembly to
a machine shop to install the bearings. There is some disagreement
whether or not they should fully seat the bearings or leave .002’’-
.006’’ of clearance.
Seems to me they should fully seat the bearings and I will adjust
for proper end-float by using the correct bronze spacer thickness
at assembly time.
I hope there is someone out there who really understands this
procedure and will provide some advise.
Thanks…Jayhawk1–
Jayhawk1
