Hello.
I have a 1985 XJ6 Series 3 that I’m busy restoring. The reverse
lights are not comming on. I’ve read various methods to remedy the
situation but to date nothing has worked. Here is what I’ve tried
and discovered:
The micro switch under the ski-slope has 2 x wires. That is the
only micro switch that I could find under the ski-slope. According
to the manual etc. this is the inhibitor switch. Whilst researching
this topic on the web, I found that this switch does not affect the
reverse lights at all.
On the auto box just where the linkage joins the box, is another
switch with 4 x wires attached to it. according to my search on the
web - this is the reverse light switch - is that correct?
Question 1: It is said that the inhibitor switch will allow the car
to start when in Park or Neutral (accepted) but that it will also
prevent the speedo cruise from engageing if the car is not in
Drive. How is it possible for one switch to monitor two different
functions with only one live wire?
Question 2: If the switch situated on the auto box is the reverse
light switch, why does it have 4 x wires and what is the function
of each?
I don’t know much about electricity or switches (as you have
probably guessed) but I would think that:
- one of the wires would be a live,
-another work in conjucntion with the position of the gear lever to
activate the reverse light,
-another sending an impulse if the car is in Drive (speedo cruise) - and the last will work in conjuction with the inhibitor switch.
Is it possible to actually test the reverse light switch and if so
how?
In a post on the web it is mentioned that the switched can be moved
until the lights come on. I beg to differ. The switch that I have,
does not have a slot that will allow for adjustment. I will be able
to do some form of adjustment on the gear cable itself.–
johan_sa
